For Users Experiencing Hangs When Downloading LiveDb Mats
Moderator: BK
To debug this issue, create a file C:\Program Files\DAZ 3D\DAZStudio4\octane_log_flags.txt and set it's contents to:
logToFile
logPrefix
logTime
logFlushTime 100
logForceFlush
liveDBDebugging
Now run DAZStudio as Administrator. If you experience a hang or lockup when downloading from the LiveDb, paste the C:\Program Files\DAZ 3D\DAZStudio4\octane_log.txt file in this thread. You must be running DAZStudio as Administrator in order for the octane_log.txt file to be created.
You need to have installed plugin version 3.5.3.30 or later when doing the above.
Laticis
Thank you very much for the heads up :)
mlru
It didn't work with version 3.4.5.29, but it did with 3.5.3.30. :)
Tested with "metal dirt v3 (2)"
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
Leonides02
Hi Paul,
You may have found a solution. After upgrading to 3.5 and running in Administrator mode, I've had absolutely no problems downloading from the LiveDB! :D
Mirana
Hate this bug. File attached
octane_log.txt
(188.54 KiB) Downloaded 1045 times
May I suggest updating to the latest version of the plugin, where this problem appears to have been resolved.
Mirana
Awesome, thanks
RGUS
Hi Paul,
Attached is the octane_log.txt file created after running as administrator and with octane_log_flags.txt created in "C:\Program Files\DAZStudio4"
Trying to load "glass, fake falloff from LiveDB
Hope this is correct and helps isolate the issue.
octane_log.txt
(1021 Bytes) Downloaded 934 times
RAM: 64GB
OCTANE PLUGIN VERSION: 2022.1..1.302 Prime
DAZ STUDIO VERSION: 4.21.0.5 Pro Edition (64 bit)
Thanks Deane. I was able to successfully download that material using the plugin. May I suggest trying to download it in Octane Standalone, and if that works, try again with the plugin. Let me know how you go. In the meantime I will submit the log to Otoy.
RGUS
Hmmmmm ... standalone, I was able to load the material, then in Studio it loaded ok... but... I don't know why.
RAM: 64GB
Return to “DAZ Studio”
