Octane Topology Auto-Repair when rendering
Moderator: JimStar
maze_vfx
Hi guys,
I'm sweating loads here and I am in need of help!
I'm really new to Octane overall and just got the Maya plugin for a project I'm working on.
In this project I have some simple text segments showing up made inside of Maya (aka with crap topo).
Everything's fine and dandy until I try and render/do a IPR and I can see that Octane is plugging the holes.
Is there any way of shutting this off? I'm desperately in need of help here, guys.
Jack
BK
Hi Jack :)
We have replied to you through our helpdesk. Have you tried using Maya Fill hole or the Clean up tool ?
Kind Regards
bk3d
calus
maze_vfx wrote:Hi guys,
Jack
This happens because the plugin doesn t support concave polygons.
To workaround the issue, triangulate your text mesh.
Pascal ANDRE
maze_vfx
Hi guys,
I've now tried both doing the Fill Hole operations as well as triangulating the mesh, neither seem to have worked for me.
Do you have any other recommendations?
maze_vfx
Never mind, sorry!
I did a proper render instead of just the IPR and now the text is fixed in both.
You're lifesavers - huge thanks!
calus
maze_vfx wrote:Never mind, sorry!
Yes obviously, once the mesh is triangulated you need to stop and launch IPR again to update the geometry.
So to be clear, the solution here was to triangulate the mesh. (the "fill hole" comand can't help and was a misunderstanding)
Pascal ANDRE
Return to “Autodesk Maya”
