Octane Render for SketchUp 3.06.1.2 Test Release
Forums: Octane Render for SketchUp 3.06.1.2 Test Release
Re: Octane Render for SketchUp 3.06.1.2 Test Release
Postby Jorgensen » Tue May 23, 2017 12:04 pm
Jorgensen Tue May 23, 2017 12:04 pm
we can't use our HTC VIVE when octane is running in the background.
octane need to pause when not in use.
jorgensen
Jorgensen
Postby -rb- » Tue May 23, 2017 1:11 pm
-rb- Tue May 23, 2017 1:11 pm
I guess it's back to old VRay
- Rich
-rb-
Postby bepeg4d » Tue May 23, 2017 1:47 pm
bepeg4d Tue May 23, 2017 1:47 pm
Hi guys,
thanks for your useful reports.
About Resetting workspace, yes correct don't use this command for now.
For now, please create a new scene outliner window:
Then place it where you want in the interface:
So now you are able to locate the Render Target node, changing its name, and more easily acces to the sub nodes:
About the GPU usage, yes correct, you can use the stop button to clear the memory and usage, but as soon as you make any kind of modification tyo the file, the GPU load goes up over 90%.
Happy testing,
ciao beppe
Postby bepeg4d » Tue May 23, 2017 2:43 pm
bepeg4d Tue May 23, 2017 2:43 pm
I forgot to say that, for updating viewport, you can click the red Octane logo button in SU interface to resend the entire scene and update the view, without closing the octane window.
ciao beppe
Postby -rb- » Tue May 23, 2017 3:03 pm
-rb- Tue May 23, 2017 3:03 pm
Thankyou Beppe for your work on this
- Rich
-rb-
Postby -rb- » Tue May 23, 2017 4:49 pm
-rb- Tue May 23, 2017 4:49 pm
I have had around 7 crashes today while moving / cutting and pasting geometry...
- Rich
-rb-
Postby -rb- » Tue May 23, 2017 5:00 pm
-rb- Tue May 23, 2017 5:00 pm
'Building Octane Geometry' just hangs...SketchUp 2017, Win 10
- Rich
-rb-
Postby haze » Tue May 23, 2017 6:58 pm
haze Tue May 23, 2017 6:58 pm
Thank you all for your enthusiastic reception of the plugin and issue reports. Regardless of internal testing we anticipated some problems, and CC is working on these right now.
Please keep in mind that there is a good deal of changes made in Octane core to make the major changes you see in the plugin happen. Octane is on a different development cycle, but we will of course try to make these coincide with the plugin test releases.
smicha -- regarding the shortcut buttons on the node stack - I made the change but this caused some issues in Modo plugin, so I had to revert it. I'll be working on a permanent solution to this soon, but am currently stuck on another task. Please bear with me.
About the window layouts - we are able to reinstate the scene outliner by default, and will have the plugin maintain the changes to the layout on exit. As for the rest of the issues, thanks again for your reports, we will be looking into them.
haze
Postby CaptainCrowbar » Wed May 24, 2017 5:03 am
CaptainCrowbar Wed May 24, 2017 5:03 am
We have a new build currently in internal testing. If all goes well we hope to make it available tomorrow.
Changes since the test release currently on the forum:
- Should waste less time converting geometry when the render window is not open
- Default layout now includes the scene outliner
- Workspace layout is saved and loaded with the scene
- Node graph editor should not lose track of the sandbox when the window is closed
CaptainCrowbar
Postby smicha » Wed May 24, 2017 7:05 am
smicha Wed May 24, 2017 7:05 am
CaptainCrowbar wrote:We have a new build currently in internal testing. If all goes well we hope to make it available tomorrow.
Captain,
Is this possible in shorter time, next release, we'd have geometry nodes available in the node graph? IMO this is critical for working with external obj/ocs.
Win7, Modo 10.1, Octane for Modo and Sketchup, nVidia latest, TITAN+3x780 6GB, 2600K, P8P67WS, 32GB, 1350W
SMH10, EK, Airplex_480, SR1_560, 20xNB_PL2, 2xD5, Aquaero 6XT
smicha
PreviousNext
Return to SketchUp
Tue Oct 27, 2020 10:08 am [ UTC ]
