Shadow catcher...
joshkitney
Hey Otoy
I'm rendering out a studio car shot and the shadow catcher is reporting dark.
It's lit with two area lights and a HDRI. I have a background image loaded and Alpha Channel checked.
When I use the Modo shadow catcher option I get the exact same result.
Any answers?
Peace.
i7 5960X Haswell-E 8-Core OC 4.2GHz // 2x GTX 980 Ti Superclocked+, 1 GTX 670 // 64GB's // Windows 10
acc24ex
so I got this answer at one point..
"Shadow pass shows all direct light shadows that calculated on the first bounce.
This includes sun light, but excludes sky light or texture environment if importance sampling is disabled or the texture environment doesn't consist of an image.
The reason for this limitation is that those light source are not included in the direct light calculation and Octane doesn't shoot an explicit shadow ray and with that can't calculate a shadow.
The shadows are weighted by the contribution of the light source casting the shadow."
.. so far, shadow catcher works as you would expect it if you use it to catch shadows and hdri is behind, if you add some more backplates and stuff it gets mushy.. anyway I'm still struggling with this..
- it doesn't take account of the actual backplate you're resting the model on to light the model up, just catches the shadows
joshkitney
Sheesh, they can put a man on the moon with less power than an original iPod, but can't make a shadow catcher just catch shadows.
Thanks acc24ex :)
acc24ex
post back if you got a solution..
joshkitney
Well the plot thickens...
I turned off the folder containing the body of the car and this happened.
Shadow catcher is working as I'd like it to.
What gives Face_Off?
I'll turn off meshes one by one and see if it's a material tag or something.
Peace
Josh
joshkitney
Okay I've zeroed in on the problem.
I have the headlight assembly turned off and the shadow catcher works like it should.
The left light assembly is geo, and the right is instanced.
I turn off the meshes with blackbodies attached to them (lights) and the shadow catcher works... turn them on (make visible in the item tree) and the shadow catcher gets busted.
Peace.
Josh
If you export this scene to ORBX and then submit it to Otoy in the Octane 3.06 Standalone release thread, the Otoy devs can investigate.
Return to “Foundry Modo”
