OctaneRender® for Maya® 3.06 - 10.20 [OBSOLETE]
Moderator: JimStar
BK
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octane Render™ Standalone on your machine.
For network slave and daemon please download the Standalone installer here:
viewtopic.php?f=24&t=60772
CHANGES SINCE THE PREVIOUS VERSION
  • Urgent fix on loading the material node.
  • Adaptive Sample default value
Bug reports:
viewtopic.php?p=311957#p311957
viewtopic.php?p=312520#p312520
viewtopic.php?p=312586#p312586
viewtopic.php?p=313008#p313008
Windows
DOWNLOAD
OctaneRender for Maya10.20
OctaneRender for Maya DEMO 10.20
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 10.20 Linux
OctaneRender for Maya DEMO - 10.20 Linux
OSX
Installation:
- Just run the auto installer file.
DOWNLOAD
OctaneRender for Maya - 10.20 OSX
OctaneRender for Maya DEMO - 10.20 OSX
Kind Regards
bk3d
itsallgoode9
thank you very much for getting a quick fix on this prior to the next release! 8-)
renmaxhb
I will test it now
renmaxhb
Not really fixed,refereence one maya file more one time,model lost textures :ugeek: rember:save it and open it again!
FIX IT NOW PLEASE,my project is ready to render :cry:
renmaxhb
Look the white guy!
calus
renmaxhb wrote:Not really fixed,refereence one maya file more one time,model lost textures :ugeek: rember:save it and open it again!
Renmaxhb, do you still have the bug with my Workaround ?
viewtopic.php?f=109&t=60846&start=30#p313059
Pascal ANDRE
Jolbertoquini
Sounds to me reference overwrite the shaders maybe check if is no edit from Maya on your references...maybe they are there and each time when you open your file you get this
overwrite if is that is not Octane bug...
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
renmaxhb
maya file ,test it
reference.zip
(1.02 MiB) Downloaded 300 times
Jolbertoquini
renmaxhb wrote:maya file ,test it
All good to me... I recreate the reference and all good you reference scene has edits on it. with overwrite. I will try to check why this errors
Screen shot
Screen shot
Jolbertoquini
Here you are scene clean of edits...
preview
preview
reference.rar
Your scene
(1.02 MiB) Downloaded 289 times
Return to “Releases”
