OctaneRender® for Maya® 3.06 - 10.19 [OBSOLETE]
Moderator: JimStar
Jolbertoquini
renmaxhb wrote:Material lost textures allways when open a maya scence, the poly is defaut material, must click the texture reload button every time.
Hi There,
So I do not have this issues at All I think because you export has UV set with the wrong set selected please give a try to check that may help you for me I had a similar error but was because houdini had export with a extra empty UVset.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Jolbertoquini
itsallgoode9 wrote:
BK wrote:
renmaxhb wrote:must click the texture reload button every time
hi renmaxhb,
thanks for reporting on this issue. It is already on our bug tracking system and we will get it fixed in the next build. sorry for the inconvenience.
Unless a build is getting released tomorrow, this version needs to be taken down ASAP. this is not a minor bug, like you guys seems to be treating it. This is flat out a scene breaking bug.
For me is pretty stable is some sens of corse missing some features but this was always the case if you have issues with texture please check my message before.
or update a scene reference so we can see I do not have this issues in manny machines install here at office aswell at the farm.
itsallgoode9
i've already had to revert back to a former version so I can't do any real testing at this point. There may be more to it but as best I can gather this is how it went down:
1. make a scene with textures in it, in a version earlier than the current 3.06-10.19 "stable" version.
2. save
3. close
4. open in current 3.06-10.19 "stable" version
5. try to render and some materials randomly render white, as if octane thinks there was a lambert applied an not an octane material
**bonus: if you try and update the material thumbnail, the thumbnail doesn't even render. weird garbled lines show up as a thumbnail.
reloading a texture fixes the problem...but...
no way in hell i'm going through a node graph like this to manually reload every material, as a quick fix....
renmaxhb
itsallgoode9 wrote:i've already had to revert back to a former version so I can't do any real testing at this point. There may be more to it but as best I can gather this is how it went down:
2. save
3. close
**bonus: if you try and update the material thumbnail, it doesn't render. weird garbled lines show up as a thumbnail.
This is a real big trouble I founded allreadey, only thing you can do is reload images texture and change color texture,then it render well :D evry texture node :mrgreen:
calus
itsallgoode9 wrote: no way in hell i'm going through a node graph like this to manually reload every material, as a quick fix....
This bug is triggered by the viewport Material/texture display (Yes you read right, a viewport issue triggers a render bug :shock: ...)
The workaround for this bug, is to use a viewport 2.0 mode that is not supported by Octane texture display
-> so you will have grey display of Octane Material in viewport 2.0 but no bug at render time
WORKAROUND = set the viewport 2.0 mode to DirectX or OpenGL Core Profile.
more information on this bug here:
viewtopic.php?f=110&t=60965#p312981
Pascal ANDRE
FrankLIU
gah5118 wrote: another side note regarding expand/collapse, I just tried it with a material node... when i hit collapse... the entire node evaporated. bug?
the issue(delete if a node is not connected) has been fixed and will be out in the next release.
I hope this deletion was what happened on your side
Return to “Releases”
