Cinema r18 octane 3.06 test4
full_ao take has a "AO" render setting which has "override kernel setting" enabled.
the next take, named veins_glass has its own render setting without "override kernel", but it still takes the "override kernel" from the full_ao take.
Other than that it runs smooth, thanks!
Version 3.06.2 - obsolete stable
- PiotrAdamczyk
- Contact:
No crashes here so far! Great work once again aoktar!
works fine on R17 and R18
Intel Xeon 12-Core @ 3.46GHz X5690 | 64GB DDR3-1333 RAM | Nvidia GTX TITAN X 12GB
OSX 10.10 / C4D R18.041
- nycjunglist
I've been using 3.06 Test4 in production for about 2-3 weeks now, and it's been pretty solid. I needed the motion blur support for Realflow fluids, so thank you for that, aoktar. Two things:
1) It seems that with the Folders option enabled in the Render Passes settings, if you use a token as a directory name, an extra folder with the token name will be created. Everything seems to save as normal in the proper directory though.
2) Is there support for Realflow wetmaps? If so, how can they be used?
Ryzen 9 5950x | 128 GB RAM | 5090 + 3080Ti
I really love that Resolution scale option in the LV. Any chance that could be changed into a slider?
Here also seems very stable.
In particular on big scenes, that at the moment not render with 3.05 and 3.06 TESTxx, finally works!
Great job.
Also seems to work very very well the "Texture Caching" option, I'm testing on our big scenes.
I'll keep you informed.
Thanks and many compiments for the update.
Great job.
i9-10900x, 96GB DDR4, 2xRTX 2080 TI, ASUS X299 SAGE, Windows 10
http://www.visual4d.it
- Tejaycheung
is there any chance to let lv scaled picture to save as unscaled size while doing file > save as..
many thanks.
many thanks.
- Domenicozzo
- Contact:
Hi Ahmet, thank you for this release. It's working great for me except for this weird thing about the triplanar node: when I try to apply the triplanar node to a slot already "occupied" (by an image texture or rgb node for example), Cinema freezes. Tried in different scenarios with different materials and it always happens. Is that happening just to me?
Domenico
Domenico
I've an issue with C4D Plugin version 3.06.
On my notebook Asus N551j (Win 8.1) with GTX860M, i work with Octane plugin version 3.05.3 and everything run properly. (the geforce driver in use is: 359.12)
Today i tried the new plugin version 3.06 and Octane can't find any GPU available.
Have anyone encountered the same problem?
thanks in advance for any suggestion
You are running the latest CUDA driver as well?cirasa wrote:I've an issue with C4D Plugin version 3.06.
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
Not possible because it's changin render output size.Tejaycheung wrote:is there any chance to let lv scaled picture to save as unscaled size while doing file > save as..
many thanks.
