octaneRandomColorTexture [SOLVED]
Sub forum for bug reports
Moderator: JimStar
C. RAM Capacity (i.e. 6 GB)
Jolbertoquini
Hi Guys,
Is a actually bug at any plug from a long time now about "octaneRandomColorTexture" only works with particles instances and not a poly instance with any type of geometry of course I understand need to be scatter.
here a example scene:
You can see a " instancer1 2 and a group with poly instance "instancer1_geo_grp" with the same shader applied.
If I export to standlone is working when I get the transform list for both with une base mesh.
Please any advise?
random_OC.rar
(16.13 KiB) Downloaded 366 times
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
calus
This bug is still not fixed in OctaneRender for Maya 3.05.1 - 9.19
The Random Color Node doesn't work with regular Maya instance (only works with particle instancer).
This is a very important feature from OctaneV2 and indeed the random color node is made to work with regular instance first.
https://docs.otoy.com/#standalone-v2-us ... exture-map
The sample scene attached has 3 regular instances using the same material with a random color node.
instanceRandomColorBug.zip
(23.92 KiB) Downloaded 341 times
So each instance is connected to the same shading group in Maya:
When exporting the scene as ORBX we can see in Standalone the problem and why the Bug happen:
instanceRandomColorBug.orbx
(98.1 KiB) Downloaded 355 times
The geometry instance is conected to 3 shaderMap but should only use one like this:
instanceRandomColorBugCorrected.orbx
(97.75 KiB) Downloaded 338 times
So to fix this bug : Instances using the same Shading Group in Maya must be exported to Octane as geometry using the same Material Map node.
(but obviously Maya instance with different shading group still need different Material Map node)
Pascal ANDRE
calus
@Jimstar,
This is not a new feature but a mistake in the plugin since 4 or 5 years, in the Maya regular Instance implementation (cf. previous post)
This bug is still not fixed in OctaneRender for Maya 3.06.4 - 10.18
Pascal ANDRE
BK
Hi Jo,
Please find the file attachment and let us know how it went :)
random_OC.7z
(21.34 KiB) Downloaded 333 times
Kind Regards
bk3d
calus
BK wrote: Please find the file attachment and let us know how it went :)
viewtopic.php?f=24&t=61365#p313894
Pascal ANDRE
Return to “Bug Reports”
