Hi! This is a test build of the OctaneRender™ 3.0 for LightWave™ plugin version 3.06.0, available for Lightwave 10.1, 11.6 and 2015.3 Windows x64 and OSX.
Release 3.06.0.4
https://render.otoy.com/customerdownloa ... _Win64.zip
https://render.otoy.com/customerdownloa ... ve_OSX.zip
Standalone version for the network rendering nodes
https://render.otoy.com/customerdownloa ... t4_win.exe
New features
New Octane 3.06 features: viewtopic.php?f=33&t=60014
A list of all the new features is provided here: viewtopic.php?f=33&t=51679
The plugin manual is being updated to cover most of the changes. https://docs.otoy.com/manuals/products/lightwave-3d/v3/
RELEASE 3.06.0.4
* NEW PLUGIN FEATURES:
- Adaptive sampling threshold, exposure and min samples input pins added to the directLight and pathTracer kernel nodes.
- New slider in the Octane light to set the disk light shape edges from 3 to 64.
- TFD API updated to use the new 1422 TFD build in Windows.
* PLUGIN BUGS FIXED:
- Fixed a critical bug in the Displacement node internal data functions that crash LightWave while building the node GUI.
- Adapt. Noise Threshold default value set to 2%
* NEW OCTANE FEATURES:
- Added a general shadow pass, which shows all direct light shadows that calculated on the first bounce.
- Merged the greyscale, spectrum and normal texture evaluation into one function.
- Triplanar map textures can now be nested.
* OCTANE BUGS FIXED:
- Fixed crash in PMC when the maximum samples have been reached.
- Fixed a deadlock when rendering is stopped while tone mapping is in progress.
- Fixed issue that rendering won't restart if you stopped rendering during deep pixel binning.
- Fixed broken falloff texture in the texture environment.
- Fixed missing updates of the texture environment when importance sampling is enabled.
- Fixed info passes / info channel kernel on Fermi GPUs.
OctaneRender™ 3.0 for LightWave™ - Test build 3.06.0.4
- FrankPooleFloating
Yes! Thanx J!
- BorisGoreta
- Contact:
Thanks !
One of my nodes won't authenticate anymore. Where is auth data located so I can delete it ?
The authentication data is not stored by the plugin in any file currently. Have you tried to reset your node?BorisGoreta wrote:One of my nodes won't authenticate anymore. Where is auth data located so I can delete it ?
- BorisGoreta
- Contact:
I had to start the standalone on that node and input credentials there. After this the node started working again.
Thanks for the displacement fix.
- BorderLine
Hi JuanJo,
Can you tell us what will be the next steps and when about ?
Many thanks
Many thanks
- BorderLine
Documentation ! Big works ! Good luck... and thanks !
