Motion Blur stops rendering
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
coilbook
Hi if open this scene and make sure slider is where morph keys are and then open octane viewport renderer will get stuck at sample 1. If you go to octane options and uncheck motion blur it will work. It has something to do with moph modifier and poly edit above it. Especially if some vertices are selected in the edit poly mod above morphs
mb.zip
(1.88 MiB) Downloaded 175 times
paride4331
Hi coilbook,
I have not found your issue, maybe I did not understand.
Could you make some screenshots or video?
coilbook
hi i attached the picture hopefully it helps.
if you select vertices and move slider and then open octane viewport rendering is stuck at sample 1. Please make sure Motion Blur is on
paride4331
Hi coilbook,
thank you
Return to “Bug Reports”
