Version 3.06-TEST-3.1 (WORK IN PROGRESS BUILDS)
fatfreemedia
This new build is absolutely brilliant, thanks aoktar!
Win10 64bit | 3 * GTX970 | i7 5930k | 32GB
Win10 64bit | 2 * GTX970 | i7 4790k | 16GB
Win10 64bit | 3 * GTX980 | i7 5930k | 32GB
Win10 64bit | 3 * GTX980 | i7 5930k | 48GB
Win10 64bit | 3 * GTX1070 | i7 6850k | 64GB
zinogino
Decided to use it for a commercial gig, so far so good!
Update:[/color]
so currently I'm rendering an animation via C4D Render Que and I noticed some errors in console line.|
Here's my log and screen grab.
Is it because of my scene (C4D) or from Octane?
octane 3.06 TEST 3 170318 152542.log
(133.66 KiB) Downloaded 338 times
eyeonestudio
3.06 PMC Kernel : Not Stable
I make spectrum scene(Use DR-render, No Scattering Shader, No Fog).
An error occurs when the sample is almost completed.
Unfortunately I can not get logs. :oops:
3.05.3 is OK
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
zinogino wrote:Decided to use it for a commercial gig, so far so good!
Update:[/color]
i think C4D. Don't know any messages in Octane like that.
eyeonestudio wrote:3.06 PMC Kernel : Not Stable
3.05.3 is OK
Open bugreport.txt and check top lines. If it's like that: "octane.dll: Octane::RenderResultStatistics::progress...." so it's about renderer.
eyeonestudio
3.05.3 is OK
The attachment aa.png is no longer available
Ok... I got "Bug Report". ;)
_BugReport.zip
(26.2 KiB) Downloaded 347 times
eyeonestudio wrote: Ok... I got "Bug Report". ;)
_BugReport.zip
Crash is on renderer. Do you mind to share your scene and description to reproduce?
calus
_BugReport.zip
Hi Ahmet, this crash seems similar to the one noticed in the Maya Plugin and in Standalone (PMC octane core bug) ,
viewtopic.php?f=110&t=60027#p307121
Pascal ANDRE
calus wrote: Hi Ahmet, this crash seems similar to the one noticed in the Maya Plugin and in Standalone (PMC octane core bug) ,
Maybe yes! Only thing i can see that's a crash on renderer not ended in plugin side. So that's why always asking for scenes and more information. To try and expecting to get same crashes on our system.
bomperstudio
We have an issue as we can't use this test version as it needs cuda 8.0 and we're on Mac OS X 10.10.5 are there any builds that cover our cuda which is 7.5.30?
Are there any big advances in terms of speed and quality in this version compared to the latest stable version?
Return to “Releases”
