If I do not change the noise threshold to the lower side, is displayed correctly. I apologize for such a long post.
OctaneRender™ Standalone 3.06 TEST 3
After changing the noise threshold during the rendering sampler does not work correctly. Shows that reached the threshold in dark areas and continues to render there where everything is clean, judging by noise passes.
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
- MildMustard
Hi Mikinik, where you marked clean it looks like it is still a little noisy to me but more to do with glossy reflection. I think it is still trying to clean up that, that is why it hadn't gone green.
Do you mind sharing that demo/sample classroom scene? I have been looking for it everywhere...
MildMustard, I think this is an error, the noise does not go away. On the second from bottom picture shows how it should be.
original .obj file https://www.dropbox.com/s/qk0y01nwex4vc ... m.rar?dl=0
- MildMustard
Oh ok, sorry i misunderstood. It could then very well be a bug.
Thanks for the classroom file
I am getting instant crashes when toggle Stop/Start render if samples less than 22.
This happens in SA and with in Modo with plugin.
Anyone one else getting this same behavior?
I know this is TEST - however thought I would bring it out.
win10 - GTX1080 -
./rrb
win10 - GTX1080 -
./rrb
- Daniel_Ward
- Contact:
Hi Guys,
I'm getting a lot of crashes to desktop trying to work with imported .obj files in 3.06 TEST (all builds). Interestingly if I try to edit the same files through the node tree editor built into the ArchiCAD plug in, I don't have any issues.
Anyone else experiencing any issues?
Cheers, Dan.
Cheers, Dan.
+MAP Architects, Christchurch - New Zealand
ArchiCAD 4.12 - ArchiCAD 24 || Octane for ArchiCAD
i7-7700K - Gigabyte Aorus Z270X Gaming 9 - 32Gb RAM - 3x Gigibyte GTX1070 G1 Gaming - Window 10 64Bit
Is this problem reproducible? Could you send us an example scene and a description how to make it crash? Thanks.Daniel_Ward wrote:Hi Guys,
Cheers, Dan.
- Daniel_Ward
- Contact:
Hi Marcus,
yip, no problem. Can you PM me an E-mail address and I'll drop some orbx files containing the objs onto my OneDrive for you to download. They're Evermotion and AXYZ design models, so not ok to post in the forum.
Cheers, Dan.
Cheers, Dan.
- BorisGoreta
- Contact:
Any idea why out of core is not working on the nodes and works on the master computer ?
viewtopic.php?f=9&t=60210
