Version 3.06-TEST-3.1 (WORK IN PROGRESS BUILDS)
eyeonestudio
No Problem.
Octane is the best for me.
Thanks.... :P
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
Test3 builds are available in first page. I've recommend that to all. Cuda errors hopefully should go away in this build. Enjoy it and please drop some feedback about problems or impressions! Enjoy it!
eyeonestudio
WOW.... Thanks... 8-)
Auto Insert Detach : Working good...
desire
Have found some bugs in latest test builds.
The first is a strange behavior with using matte material in LiveViwer (see first two attachs)
Second - when PV render scene with matte mat + alpha enabled, there is no data in alpha channel in saved file.
And the third - crappy results using render layer mask feature (see last attached pic) on standart settings. I don't know, may be I was wrong, but over non-test version it was Ok from the box.
matte mat, alpha channel enabled
matte mat, alpha channel disabled
layer mask sample
layer mask sample
desire wrote:Have found some bugs in latest test builds.
Could you check it again? Because i can't see anything wrong on my test. For 3rd, it's not a matter because crappy pixels are out of mask.
desire
crap! )))
Sorry about first two points - forgot sometimes that if you had some stranges, it's needed to copy objects in a new scene initially to verify bug :idea:
It's Ok and working as expected.
About layer masks - not render layer feature, that has it's own alpha channel, I'm talking about render layer mask - it has just layers respectively to objects' IDs with applied transparency, so crappy pixels is making mask edge.
I'll make more tests... Thank you
update: sorry again and again, aoktar - after moving objects in a new scene, there are no bugs like I wrote earlier :oops: :|
VVG
Hi, aoktar
When using Octane Scatter, critical errors often appear. They appear on different actions.
I sent you a private message from the screen
Do you plan to add an infinite plane like in standalone 3.06?
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
desire wrote:crap! )))
Np! Propably some settings was messed.
VVG wrote:Hi, aoktar
Thanks! Answered.
Infinite plane needs to be investigated more. There was some possible problem about uvmapping but i think it can be ignorable. Yes propably i'll use it for floor objects.
lucioing
Hi Ahmet!
Strange behavior: the sphere didn't update but the material is ok.
Node editor pressed, nothing happens ...
L.
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
Return to “Releases”
