I found a bug in OctaneRender® for 3ds max® v3.05 - 4.30 [STABLE] when you create Octane daylight and add inside RGB texture all is good, but when I want to add another texture to Rendering/Environment tab/Texture environment to be able to use it as backplate I can switch between two HDR but I can`t use sun anymore? In standalone I can use two HDR+sun.
I also attached files.
Octane daylight and backplate problem SOLVED
C. RAM Capacity (i.e. 6 GB)
- mark0spasic
- test.zip
- (78.9 MiB) Downloaded 395 times
- test standalone.zip
- (78.87 MiB) Downloaded 362 times
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
- paride4331
Hi mark0spasic,
attached a screenshot about sun+hdri workflow.
The following links can be useful:
viewtopic.php?f=27&t=41933&start=10#p306069
- mark0spasic
Thank you paride4331 so I need two suns to be able everything to work as it should. In standalone this is more intuitive than in max.
It would be nice to update manual.
