Hide to camera
fabrizio_s
Hi Paul,
It is the windows glass of the palet plugin created by Formatio (Mac)
Fabrizio
Can you post a screenshot of the glass material setup pls.
formatio
Hi guys
The material looks like this:
The two options that are below the edge are film width: 0 and film IOR: 1.45
One thing thou - that I think has no effect - is the absorption medium - is set to black so doesn't absorb anything (it shouldn't be there, I think that v3 adds it by itself (materials were created and saved with v2))
Fabrizio: is your glass geometry built form two faces or just one plane?
Regards,
Mac
fabrizio_s
it is a parallelepiped.
fabrizio
formatio
Hi
Could you just post your the scene here?
Regards,
Mac
fabrizio_s
here is the scene in rhino format
http://www.filedropper.com/c2b
bye
formatio
Ok I think I know where is the problem and how to fix it.
The live geometry setting is ok - problem is that refraction (which happens with specular material) - bypasses the "visible to camera" setting (that is probably due to its involvement in GI calculation etc).
To over come this effect - instead of specular material in glass use standard glossy material with black color, IOR set to 8 and lower the opacity. You get the reflection, but the plane is not visible.
That is the only way I believe
Regards,
Mac
fabrizio_s
Hi Mac and thanks a lot for your suggestion.
However, I think it would be better to fix this problem in the next version of octane.
Bye
fabrizio
franchais
It would be really good if Live update could work with work session files. Not sure how you would implement that.
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
Hi - turn Smooth OFF - since the glass needs to have hard edges in order to render correctly. Also make your the Kernel->Ray Epsilon is less than the thickness of the glass. https://docs.otoy.com/manuals/products/ ... ayepsilon/
Return to “Rhinoceros 3D”
