New interface please
I have an Octane VR subscription...and this release does'nt start.
I will do a VR release of the Rhino plugin after the next test version of Octane 3.06 is released.
fabrizio_s
ok thanx
fabrizio_s
Hi Paul,
this new feature is really useful and I love it.
Is it possible to insert in the next release a similar button (Collapse) in material editor?
With complex material (with many nodes) it's annoying to close every function to simply the tree and to find the function I need to modify.
It will be usefull to have a button (graphic button or a text button) to collapse and close every open function but the first (to speed up the search of a funcion inside the material tree) - see the pic below
Thanx a lot
I will add this to the next release.
You can post images in forum messages - which is easier for people to view (since www.image-share.com is blocked by some firewalls - including mine).
fabrizio_s
Ok,
thank you very much!
A window appear: "Your license was deactivated and could not find another one available. You may release a new license and retry or sign in as a different user to continue" etc. etc..
What was the name of the installer you used pls?
In general, I push out full commercial TEST releases quicker than VR releases. The idea of the VR releases is that they are released for STABLE builds rather than test builds.
fabrizio_s
when I wrote it, I tried to instal OctaneVR_3_05_1_win.exe with OctaneRenderForRhino3.6.1.79 PRE-RELEASE...and if I not mistaken even with OctaneRenderForRhino3.6.2.79 PRE-RELEASE
bye
Sorry - I missed this msg. Is this still a problem? It means you are running the plugin on another PC - so you need to close Rhino on that PC to release the license.
fabrizio_s
Hi Paul,
no, it isn't a problem.
It is strange because I have only one pc with Octane.
bye
Return to “Rhinoceros 3D”
