C4D crash to render 16000 x 16000px image
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
zamak
_BugReport.txt
crash bug report
(406.34 KiB) Downloaded 219 times
Operating System : Win10
Graphics Card(s) model : 2 TITANX
RAM 64Go
Nvidia driver version 8.0
OctaneRender Standalone version 3.5.3
OctaneRender plugin version 3.5.3
Host application version C4D
A detailed description of the issue and steps to reproduce it (Include Screenshots or video capture), as well as an example scene if applicable.
Hi there, I've been encountering successive crashes with Octane when I am trying to render an image of 16000x16000px in 350 dpi (requested by client).
The preview while rendering split the image into mosaic and finally (if no crash) the image is split in 2 as in attachment
result direct lighting 20 samples
octane 3.04.5 170303 165556.log
Octane log window
(48.58 KiB) Downloaded 205 times
_BugReport.txt
crash bug report
The C4D scene is simple and local (hosted on computer). We 've tested in low poly and without any textures, still crahsing or weird results as in image below.
Any idea, similar experience or any known limitation I am not aware of to get the right image in the requested format/size/def?
Quite important and urgent, your help would be more than appreciated.
Are you sure that you're not out-of-physical RAM? Btw i see in your logs that you didn't deleted another octane plugin versions.
zamak
Hi Aoktar
Actually I first tested with Octane 3.05.3 version, and as it was not working, I down graded to 3.04.5 (which did not work better).
and btw I tested to render by region, and same results, the image is split and displaced.
Regarding RAM, I have 64Go physical RAM and from what I see in log report, total used RAM:9.046Gb.
Any advice?
zamak wrote:Hi Aoktar
Any advice?
I can easily render scenes at 16k square. So it should work on you also. Can you send your scene for testing? It's a requirement in bugreports list when that's possible.
Btw you overlooked my message i think. There should be another versions of plugin. Can you check c4doctane folder content?
zamak
Si I've reinstalled the latest version 3.06 of Octane.
But same issue : split screen and crash of C4D, see
bug crash C4D text box
and the corresponding bug report
_BugReport.txt
bug report2
(412.34 KiB) Downloaded 223 times
The scene is now available
KV01.rar
C4D scene
(10.4 MiB) Downloaded 192 times
- for confidentiality disclosure, I removed the textures (but I've also made the test without textures before posting - so i am assuming that there are no issue with them).
So now I am completely up-to-date, same issue for this size of picture.
Thanks for your follow-up and support
zamak
I tested a new rendering, now I have errors cuda 702 ....
octane 3.06 TEST 2 170303 182154.log
(26.75 KiB) Downloaded 204 times
Yes i get same errors. It seems related with HDRLS usage. Can you send a render to LV then call "Edit In Standalone" command? Worth to try a render in Standalone directly.
zamak
Ok, It seems to work with Standalone version.
zamak wrote:Ok, It seems to work with Standalone version.
at target resolution? It's crashing on me.
zamak
At 16000 x 16000px for me
Return to “Bug Reports”
