Hide to camera
fabrizio_s
is there a way to hide some objects to the camera but not to GI?
I think what you are after is a reflection pass (where you see the objects reflection, but not the object itself). You can do this by enabling render layers. then rendering a Reflections pass (I think you need Alpha Channel enabled in the Kernel). See https://www.youtube.com/watch?v=ozW98ZjeXYM for details.
fabrizio_s
Hi Paul,
I have an interior scene enlighten by sun and sky. In the exterior part of the scene a put a plane to better light up the interior by the bounces of indirect light that come from the plane.
But in the final rendering I don't want to see this plane from windows because I want to put an image as a background.
Sorry for my english
Bye
Fabrizio
formatio
You can use diffuse material and set it to "shadow catcher" mode, or make it live geometry and set invisible to camera/shadows
Regards,
Mac
fabrizio_s
Thanks a lot Mac
fabrizio_s
Hi Mac,
i tried both methods but they seem not to work.
formatio
Hi
Check this out
This is normal
normal mode
normal mode
This is live geometry :
live geometry with settings
With this settings:
settings
settings
Does exactly what you wanted.
Regards,
Mac
Mac, I think Fabrizio wants the reflections in addition to the emitted light. If not, then if it's an emitter, you can also set the material opacity to 0.
fabrizio_s
Hi to everyone,
the "problem" appear with glass. Take a look to the images. The first is with glass on the windows. The second is without glass.
In the first one I can see hdri and the plane (or the reflection of the plane?) on the exterior scene
In the second one I can see the background (as expected)
(light: hdri - background: RGB white)
So how can I avoid it?
thanx
Can you post a screenshot of the glass material setup pls?
Return to “Rhinoceros 3D”
