OctaneRender® for 3ds max® v3.05 - 4.30 [OBSOLETE]
paride4331
Hi Elvissuperstar007,
I asked a vraymax already converted, not a substance painter file.
Could you kindly run that script and prepare a vray/max for me, please.
Goldisart
birds - for
substa/// painter - - vray - octane = = = converter
sub
sub -to vray
sub- to octane - not
vray to octane - bad
pack
https://yadi.sk/d/nMrYaXbr3EtQgz
Goldisart
I think this question should be written in the https://www.allegorithmic.com - what would they have received the detailed process of conversion to octane render and I think the team here should immediately and quickly address the proposal in https://www.allegorithmic.com
Goldisart
since you have no Converter ... only can work with simple materials
paride4331
Hi Goldisart,
thanks for your file.
Goldisart
https://skfb.ly/66AoE
https://skfb.ly/66sQS
it would be good to write a script which would have translated materials in 3Dmax without settings of each material ... for example in VRAY it is implemented
https://hocuspocus-studio.fr/tools/prod ... o-maxvray/
SubstancePainterToVRAY.rar
(7.51 KiB) Downloaded 247 times
kcpr-raffaEl
haze wrote:We are expecting the release version of 3.06 in the next couple of weeks. The SDK is in test stage right now and is still getting some significant changes. We are trying to hit a balance between putting out releases earlier versus spending that effort on fixing issues instead. In this instance we decided to focus energy on fixing more issues on our Max list so that when 3.06 is released, then we will have a much more stable and well tested plugin.
Thanks for your response!
But, maybe there is any chance to speed things up? Even releasing not super-stable version?
I've got renderings just waiting for AS option, which dramatically shortens my render times...
Rendering form Standalone is almost impossible for some reasons for me.
profbetis
kcpr-raffaEl are you familiar with the animation export that the 3DS Max plugin provides? I recently tried it and it worked perfectly for my animation.
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
kcpr-raffaEl
profbetis wrote:kcpr-raffaEl are you familiar with the animation export that the 3DS Max plugin provides? I recently tried it and it worked perfectly for my animation.
Yes, but my reason is that exported scene doesn't support Octane Camera Correction. Camera is on its place but is not recognized in Standalone as OCTANE Camera and I can't enable Correction.
Elvissuperstar007
Bug
Bug Displ.rar
(27.89 MiB) Downloaded 260 times
Return to “Releases”
