Hey there,
i need to render ies lights. I got Eulumdat and IES Files. The Eulumdat Files render wrong both in Octane and Modo. The IES light is much softer in Octane. Is there a way to make this match the Modo render?
1. Octane IES
2. IES in OpenGL
3. IES in Modo Render
4. Eulumdat in Modo Render
Thanks in Advance!
IES Light Problem
I suspect the IES light is rendering in a truer, more realistic fashion than Modo, so I doubt you could tweak the Octane IES lights to render in a harder fashion (unless you tweak the IES file).
Are you able to send me the .LXO and .IES file pls - and I will take a closer look to see if something can be done.
- Hesekiel2517
Thank you for the quick reply!
I made a test scene:
The first Photometric Light is created with no modifications (The result is very soft and only lighting up)
The second Photometric Light is scaled to 1% (The result is a little sharper but again only lighting in one direction)
In Additon I made a small sphere (The result is sharp and is looking like the modo photometric light)
I also noticed that the Modo Photometric light has a width and a height, which also changes the softness. Maybe this has to be taken in account when an octane Light is created.
Thanks again for your great work and the perfect support!
- IES_Octane.zip
- (26.5 KiB) Downloaded 301 times
- Hesekiel2517
I also loaded the file in IES Viewer. This is how it looks there:
I also found out that for Maxwell Render it is recommended to use a little sphere as emitter:
http://support.nextlimit.com/display/mx ... S+emitters
I will look into this in the next few days.
