Which driver for MAC with Octane Test Version?
Ron
I want to try Octane on a Mac Pro (MacOS 10.11.6) with the test version 3.04.3.
When rendering Cuda error 719 appears. I guess it's a driver issue. Which version of the Nvidia driver is the correct one.
My card is a GTX 780 TI.
Thanks for any hint!
Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Hi Ron,
no problem here with 10.11.6
what version of CUDA drivers have you installed?
ciao beppe
Ron
Beppe, thanks for your reply.
I actually have the same driver versions like you have.
I am using the original AMD graphics card for display and the Nvidia card for rendering. Could this cause the problems?
Last test with a simple scene (cube and daylight) leaves the LV black and nothing else happens.
Ron
Hi Ron,
have you tried with Standalone?
Do you have the same behavior?
Try to roll back to an older version of CUDA drivers, the last one are not perfectly stable.
ciao beppe
Ron
I tried one of those sample scenes of Otoy in stanalone.
The result is this:
OctaneRender 3.04 Demo (3040000)
CUDA error 719 on device 0: unspecified launch failure
CUDA error 719 on device 0: unspecified launch failure -> failed to load module
device 0: failed to initialize resources
device 0: detected an error on render device! trying to recover...
CUDA error 719 on device 0: unspecified launch failure -> failed to bind device to current thread
device 0: failed to recover - giving up and switching device to failed
Hi Ron,
please, try to remove the AMD card and try only with 780ti, note that probably you will see a black screen on boot until the desktop suddently appears.
ciao beppe
Ron
Looks like a faulted card. Tried the Nvidia card only but the screens remained black ...
Bad ...
Ron
I got another GTX 780TI and tried it solo - without the AMD card. The card is recognized by Octane etc. but now CUDA error 700 appears.
What can I do to get this working?
Hope someone can help!
Ron
Here is the Log:
cudadriver-7.5.30-macos
NVIDIA driver 346.03.15f06
Started logging on 07.03.17 15:21:03
OctaneRender 3.04.3 Demo (3040300)
Tried to access attribute via invalid ID A_ALLOW_STATISTICS_COLLECTION (10)
Scene created in plugin version -1
Export materials time= 98.443 ms
Collect objects time= 2.355 ms
CUDA error 700 on device 0: an illegal memory access was encountered
CUDA error 700 on device 0: an illegal memory access was encountered -> kernel execution failed(report)
CUDA error 700 on device 0: an illegal memory access was encountered -> failed to copy memory from device.
device 0: direct light kernel failed
CUDA error 700 on device 0: an illegal memory access was encountered -> failed to deallocate device memory
CUDA error 700 on device 0: an illegal memory access was encountered -> could not get memory info
CUDA error 700 on device 0: an illegal memory access was encountered -> failed to deallocate pinned memory
CUDA error 700 on device 0: an illegal memory access was encountered -> failed to unload module
Mesh creation time = 114.318 ms.
Triangles:0 Disp.triangles:0 Hairs:0 Meshes:0
VRAM used/free/max:345Mb/1.722Gb/3Gb
Out-of-core used:0Kb total used RAM:9.173Gb
Total export Time = 226.797 ms
device 0: the device failed immediately after the recovery -> giving up and switching the device into error state
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
Device:0 TotMem:3Gb rtData:341Mb film:4Mb geo:0Kb node:2Kb tex:0Kb unavailable:962Mb
Yan
I get the same error (700) with 3.06 on mac with BizonBox egpu. I think this is a bug in the render engine, because with 2.053 everything was fine. Also changed video cards with no success.
Hope this can be fixed.
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, 4x EVGA GTX 1080Ti, Octane-for-C4D 4.x.x, Nvidia 398.82
