"use viewport background" option doesn't work?
Norman_Stansfield
Hello,
Is Kernel option "use viewport background" working at all? I can't use the animated background file seen in my 3dsmax viewport. Texture environment is deforming a bitmap into a sphere.
I need to match photoreal lighting to the video in background.
I couldn't see any effect of "use viewport background" option on and off.
I have version 2.05b, max 2014.
All the best.
jamestmather
Hi - any answer on this - can't seem to get Octane to show the environment map in the viewport. Any suggestions?
justix
jamestmather wrote:Hi - any answer on this - can't seem to get Octane to show the environment map in the viewport. Any suggestions?
Hi James, did you sort out the matter? I also need to render the viewport for matching image but it does not seems to work.. im on max 2014
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
ramone163
Octane team... Any solution to solve it?
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
paride4331
Hi Ramone163,
a screenshot for you.
ramone163
paride4331 wrote:Hi Ramone163,
Thank you paride4331.
One problem is that video (sequence images) dont refresh in Octane render viewport. You need to close it and open again to render right frame from video background.
mikinik
paride4331 , not work for me. have tried many times on different versions of the plugin and never worked. how to be?
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
HHbomb
you need to check "alpha channel" in kernel type section.
Cathodeus
I'm sorry but having to check "alpha" option if "Use viewport background is already checked" is a total non sense ! We should be hable to see the viewport background once "Use viewport background is checked".
And if we need an alpha for compositing purpose than wwe will check "Alpha channel"
I want to use "Viewport background" without alpha. And being hable to see it an save it without alpha
paride4331
Hi Cathodeus,
you could solve your needs with this workflow:
viewtopic.php?f=9&t=59392&p=304010#p304010
Return to “Autodesk 3Ds Max”
