IPR window image changes after making edit to render target
Houdini Integrated Plugin
GraemeH
Hello Juanjo,
I now have the Octane plugin for Houdini and running Houdini Indie.
I have been working some simple renders but noticed that when I change something or update a value in the octane render target, the image within the IPR window changes to something totally different (usually enlarges to a different area). I do have my camera locked so I can use the viewport to change the IPR image.
Is this a bug?
juanjgon
This was indeed a bug, but it has been fixed several builds ago. Are you working with the latest version 3.05.3.0?
GraemeH
Yes. I have the latest version. See image and vid showing what happens.
Capture 03.wmv
(1.49 MiB) Downloaded 4281 times
juanjgon
Hmm, weird. I'll try to reproduce this problem here, but could be faster if you send me this scene. Is it possible?
GraemeH
Hi Juanjo,
This website would not allow me to upload the indie file for some reason. I've save it to a dropbox folder.
You can use the same file for the speed test.
https://dl.dropboxusercontent.com/u/618 ... ttle.hiplc
juanjgon
I can reproduce the IPR camera issue. I'll investigate to see why it happens. Thanks for the scene.
juanjgon
The problem is related to have in the ROP node the render target referenced to the vopnet inside the HDA. If you set the HDA path directly all works fine. Anyway I am going to see if this problem can be fixed.
juanjgon
I've fixed this issue for the next build. Thanks for reporting it!
GraemeH
No problem. Thanks for answering all of my noob questions!
Return to “Houdini”
