OctaneRender™ Standalone 3.06 TEST
manalokos
Triplanar should be a projection mode, as it is it does not help with anything if you don't have a UVW map in your geometry... couldn't you just add a Blend angle to the Box projection?
It is nice to have it as a texture mixer, but the real point is not to mix different textures... it is to avoid seams in textures.
KonstantinosD
Ok here are my initial tests, Adaptive Sampling does work just fine as you will see below,
All these are rendered with 7x1080's watercooled 2x Xeons e-5 2640 v4, at 1920x1080, pathtracing of course and the scene's only light source is a window with a light portal on the right and octane sun and sky env. Tems at max reached 44 C in a fairly hot room of 23 C with complete silence from the machine. also a shout to Smicha who build it ! I also did a super clean render at 8192 samples followed by the same quality with AS.
Here:
2X Win10 PRO, Asus ROG Zenith Extreme Alpha, AMD 2990WX , 64GB ram, 2X 2080ti, all watercooled, custom loop.
mikinik
VVG wrote:Adaptive sampling
when you use volumetric light sources Adaptive sampling useless. How to speed up rendering?
3,06 - 4,28 min
3,05 - 4,38 min
PS
in RS render Adaptive sampling works well.
OctaneBench +2 point? WTF?
of course OctaneBench 3.06 without AS
Nvidia driver 378.49
...support for adaptive sampling to the direct lighting and the path tracing kernels...
read here viewtopic.php?p=304601#p304601
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
smicha
KonstantinosD wrote:Ok here are my initial tests, Adaptive Sampling does work just fine as you will see below,
Here:
So 1:16 reduced to 0:42 ....
KonstantinosD
And 4:17 to 1:34!!! At a complete noise free image more than 3 times faster than 3.05!
smicha
KonstantinosD wrote:And 4:17 to 1:34!!! At a complete noise free image more than 3 times faster than 3.05!
Any particular settings for AS?
KonstantinosD
noise threshold to 0.038, min samples to 512 and power to 1, and up the samples a lot 25000-50000. It starts slow but it goes crazy fast after sometime!
glimpse
KonstantinosD wrote:noise threshold to 0.038, min samples to 512 and power to 1, and up the samples a lot 25000-50000. It starts slow but it goes crazy fast after sometime!
Thanks for those tests ;) looks promising!
VVG
3,06 - 4,28 min
3,05 - 4,38 min
PS
read what? in my scene just use path tracing method
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
doca
Correct me if I am wrong, but looks like AS is wasting samples on completely black areas- deep shadowed, or black material... Maybe, "path termination power" is confronting with it, or it is pointless when you have AS turned on?
