Report on all Materials
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
s3d-weyrauch
our office works with an own ArchiCAD template, and I have prepared all of the materials in Octane.
We should reorganize our server, and we had to move the textures as well (it was not my decision...). Anyway, I have to check sometimes all of the loaded textures, I would like to avoid invalid paths (old servers, user folders, etc.).
Is there any possibility to get a list from any loaded materials, that contains the path of the texture?
It would be interessant about used proxies as well...
Thank You
David
BIM team leader
Win 10 | ArchiCAD GER 23-24 | Octane Plugin for ArchiCAD
13 Licenses | Network Render over 12 graphic cards
I suspect this would not be easy to implement, but I am doing some work on the ArchiCAD plugin over the next couple of days, so I will take a closer look.
s3d-weyrauch
Thank Paul. I have tested the latest plugin, and the result doesn't show the list of the files with path.
Do I something wrong?
David
BIM team leader
Hi David - are you certain there are images in your materials? Or if the png/jpg files are missing, they will not be reported as missing either (since the image filename will be blank in the Image node).
s3d-weyrauch
Not missing, not a proxy... :( How can I serve you more info about this issue?
David
BIM team leader
I will investigate the problem when doing the 3.06 release (probably late next week).
Return to “Graphisoft ArchiCAD”
