Trying to get a render right with 2.3
I get way too much fireflies with pathtracing and HDRI is this normal?
Somebody got tricks?
Exterior render
It is normal. Down the road there will be a fix for it automaticly.
For now use this - http://www.refractivesoftware.com/forum ... 075#p25075
Amiga 1000 with 2mb memory card
Yes indeed, for the moment i haven't managed to get a clean render with pathtracing HDRI and bump/specular maps.
Defly is good but not enough for me.
Directlight seems to work... with bump and specular. Not with HDRI though, either way not with all textures.
I've seen some pretty clean renders around i don't think I get it. Which is the best version to render? is there a difference between them?
Antec 300 Casing/Windows 7 ultimate 64/i7 920/ ASUS p6T/ 6GB RAM/ Sparkle GTX470 1.2GB & Asus GeForce 8800GTs 512mb
you probably have the bump map power on the gray concrete pieces (which are full of fireflies) way too high.
use a low value like 0.1 or 0.2 max and you'll have MUCH less fireflies.
Radiance
Radiance
- Phr0stByte
So, does the 2.3 have better anti-alias filtering? Rendering at 2-3x your intended size is OK for some, but I am required to make large res renders to begin with and 2-3x my intended size will kill Octane and my system. Anyone?
Ok, much less bump, IOR and supersampling. It worked.
I didn't manage to get more illumination without burning the HDRI plate neither in Octane or in PS. I suppose they are pretty accurate.
Need more hi-quality HDRI!! hahah
I like the results. thank you all for the tips!
