Testing latest demo but Smooth not working?
justix
I'm testing the latest demo in order to understand differences between the Backplate option in the material slot and those in the Environment Slot panel..need a tutorial actually..or examples BUT I stumbled upon this artifact..if that is.. were do I adjust such smooth problem as I never had it in my 2.x version , is a Max 2016 problem or Core function not working? Thank you
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
Goldisart
little polygons - it is necessary to increase the number of
justix
Goldisart wrote:little polygons - it is necessary to increase the number of
Thanks, I believe something has changed in parsing or smoothing lower polygon than a certain number?
Sphere with 64 Segment in MAX the edges are yes visible but does not look like shadows are so bad
Same in Octane 3 but clearly with the same number of segment is noticeable
Goldisart
Hello paride4331 !!!!!!
please see ////
1/
2 /
test 2017.rar
(78.33 KiB) Downloaded 308 times
Goldisart
1
2
3
.... 7
8
paride4331
Hi Guys,
Ray epsilon can affect the render, but the geometry is subject to settings such as smooth (parametric objects), modifiers meshsmooth and smooth (Octane material).
Geometrie with few segments (screenshots) has good results, but it might have issue.
Goldisart
Hello paride
what do you think about ray Epsilon see two pictures at the top where I put the file to download ?
justix
paride4331 wrote:Hi Guys,
Hi Paride but this is textbook :) and I mean about the Polygon numbers BUT still I believe we are not getting there, look at my images again, my point was that from 2.x to 3.x ( or at least this release ) the difference between a simple illumination of a 32 segment sphere without changing the dafault Ray Epsilon is definitely different .. for the worst I mean
OCt 3
OCt 3
OCt 2
OCt 2
Goldisart
it seems to me that what with the ray Epsilon .... ( CM - world ) when the value of 0.001 of the shadow is smooth but AO is wrong with the value of 0.0001 shadows have the gap in the polygons but the correct AO
this topic should be investigated by the developers !!!!
Goldisart
I beg you to perform AO at the micro level . !!!!
probably needs to be some connection between the ray Epsilon ....and AO
Return to “Autodesk 3Ds Max”
