Octane Sketchup Exporter 1_00-04 [v2014]
Forums: Octane Sketchup Exporter 1_00-04 [v2014]
Re: Octane Sketchup Exporter 1_00-04 [v2014]
Postby TIG » Sun Mar 09, 2014 12:19 pm
TIG Sun Mar 09, 2014 12:19 pm
skibbbi wrote:How to install rbz? There is a lot of help :)
https://www.google.pl/search?q=how+to+i ... 2&ie=UTF-8
Assuming you have v8 [latest update, >=M2 ] or any newer SketchUp - v2013 or v2014, then open Preferences > Extensions > Install... button - click, then find the RBZ and it is processed for you into your default Plugins folder...
You need to add .RBZ onto the very end of the ZIP file so it is recognized...
fileName.zip --> fileNme.zip.rbz ]OR fileName.rbz] will do it...
Alternatively get the SketchUcation PluginStore Toolset.
That has a submenu item to 'Install Archive' - which processes RBZ or ZIP archives and installs the contents for you into your default Plugins folder... or if you have optional others they are offered too [unlike the native Installer...]
If you have an unsupported SketchUp version < v8M2 then you do not have an RBZ install capability - therefore you must do the manually extraction and installation from the ZIP archive as described in the documentation...
TIG
TIG
Postby perro_abombao » Sun Mar 09, 2014 2:00 pm
perro_abombao Sun Mar 09, 2014 2:00 pm
Ok Guys!!! thanks for quick response....I found the solution....in the windows control panel, folder options , view tab,I remove the check from "hide extensions for known file types"....last night I was tired and never see the file still a zip file, even rename to .rbz :oops: :oops: :oops: :oops:
perro_abombao
Postby fivebythree » Wed Dec 07, 2016 4:32 pm
fivebythree Wed Dec 07, 2016 4:32 pm
This exporter works better than the preview window crap. For anyone else having trouble, bounce to standalone its just fabulous.
STANDALONE v3 / SKETCHUP2017 v3 / BLENDER v3 / C4D R16 v3 WINDOWS7PROSP1 x64 | GTX1080ti + GTX780 | i7 4930 @3.4GHz 6 Core| 32GB
fivebythree
Postby _qmvc3WkfIhgYS » Wed Feb 08, 2017 1:11 pm
_qmvc3WkfIhgYS Wed Feb 08, 2017 1:11 pm
Can we have a 2016/2017 version of this exporter as well? Since not all features are included in the plugin (thinking Network Rendering etc)
_qmvc3WkfIhgYS
Postby _qmvc3WkfIhgYS » Thu Feb 09, 2017 10:19 am
_qmvc3WkfIhgYS Thu Feb 09, 2017 10:19 am
Ahaaaa! It is included into the plugin now! Just have to activate the preview windows to be able to save to OCS. This solves all our problems. We can now get a working render going inside sketchup then export to OCS for the heavy work when doing network renderings etc.
_qmvc3WkfIhgYS
Previous
Return to SketchUp
Mon Jul 13, 2020 3:54 pm [ UTC ]
