https://www.youtube.com/watch?v=SBHhcXZ ... e=youtu.beacc24ex wrote:So - not a stable version?
OctaneRender® for 3ds max® v3.05 - 4.29 [OBSOLETE]
See viewtopic.php?p=302530#p302530coilbook wrote:can someone from otoy respond to me. When will 3ds max users will get AO shadow color tab? It was out 2-3 months ago for a standalone release.
will there be a function to turn off individual Imager in the camera ????????? when ? I use the scene as standard and Octane cameras - adjusting the main Imager I have to adjust each camera
could be better not a OFF button and the button Imager synchronization !!!!!!!!!!!!!!
Can't you do a Camera-rig and animate the values? I do it often for several points in a scene. One frame for each camera position.
PURE3D Visualisierungen
- paride4331
Hi Goldisart,
I will ask to developers if they can create an imager bypass.
If that's simple to add, it could be helpful.
.. can octane use one light to affect only one object and none of the others .. I actually need this quite badly, as I need to combine in photoshop via selections - this is a major pain in the A, as I have a bunch of these scenarios.. rendering twice is two times more time consuming along with the post processing, so 3x longer
- of exploring if I can work this out in vray instead (you see what happens when you really need a time saving feature)
- the cast shadow works, visible to cam works, I'm using this daily really useful
- also what about the visible to ref thing - it doesn't seem to work at all?
3dmax, zbrush, UE
//Behance profile //BOONAR
