OctaneRender® for 3ds max® v3.05 - 4.29 [OBSOLETE]
Goldisart
acc24ex wrote:So - not a stable version?
https://www.youtube.com/watch?v=SBHhcXZ ... e=youtu.be
haze
coilbook wrote:can someone from otoy respond to me. When will 3ds max users will get AO shadow color tab? It was out 2-3 months ago for a standalone release.
See viewtopic.php?p=302530#p302530
Goldisart
can not duplicate, it is necessary to do the installation and in the bitmap and RGB images-sequence of images
please move this place up ... with the sequences of trouble .... especially when they begin to replace them
Goldisart
will there be a function to turn off individual Imager in the camera ????????? when ? I use the scene as standard and Octane cameras - adjusting the main Imager I have to adjust each camera
could be better not a OFF button and the button Imager synchronization !!!!!!!!!!!!!!
mbetke
Can't you do a Camera-rig and animate the values? I do it often for several points in a scene. One frame for each camera position.
PURE3D Visualisierungen
Goldisart
mbetke wrote:Can't you do a Camera-rig and animate the values? I do it often for several points in a scene. One frame for each camera position.
Yes, but you offer a cure but it can be avoided .... I raise this issue because to fix it better
paride4331
Hi Goldisart,
I will ask to developers if they can create an imager bypass.
If that's simple to add, it could be helpful.
acc24ex
.. can octane use one light to affect only one object and none of the others .. I actually need this quite badly, as I need to combine in photoshop via selections - this is a major pain in the A, as I have a bunch of these scenarios.. rendering twice is two times more time consuming along with the post processing, so 3x longer
- of exploring if I can work this out in vray instead (you see what happens when you really need a time saving feature)
- the cast shadow works, visible to cam works, I'm using this daily really useful
- also what about the visible to ref thing - it doesn't seem to work at all?
Goldisart
the principle is simple light-select - shadow light to choose
Goldisart
Return to “Releases”
