Is this going to be a feature for Lightwave?
http://inlifethrill.com/personal/whats- ... nt-fog-02/
Environment fog?
The environment medium input is located in the render target environment nodes. I think that I had posted a sample scene some time ago. Here you have it again. It is easy to configure, but you must play with the medium node in your particular scene because the effects depends on several parameters, like the scene size or the lighting setup.
- environment_medium.rar
- (21.93 KiB) Downloaded 383 times
- BorderLine
Hi JuanJo,
I'm trying to adjust environnement Near and Far. Ex : Near 4m : 0 % fog and Far 15m : 80% fog
Is it possible ?
Is it possible ?
Not like in LightWave. Remember that this is not a post effect using the Z buffer, or the camera or reflected/refracted ray lengths, so it is not as simple.
This is a true participating media volumetric rendering. You can control the medium radius, that is the size of the sphere, centered in the camera, where Octane computes the environment medium, but you need to use the medium node parameters to control the scattering and volume effects. Usually, the medium radius has a huge impact on the volume density, so you should play also with this value.
- BorderLine
Thanks Juanjo,
Interesting if we can adjust in negatif medium radius centered in camera !
