Near future plans
_qmvc3WkfIhgYS
We are using the plugin in our projects. The only real problem is that proxies are scaled 100 to big, and that we cant share projects between computers because of the temp files.
We always make sure to use the internal right click menu in sketchup to create, or unlink octane materials. Then edit them in the octane viewport.
azen
patrickbarnekow wrote:We are using the plugin in our projects. The only real problem is that proxies are scaled 100 to big, and that we cant share projects between computers because of the temp files.
Material texture sharing issues are being addressed in the upcoming version of the plugin. Material data will be fully embedded into the scene file, so that it can be more readily shared around.
-rb-
Uhm...Late Jan now - all good?
- Rich
haze
Apologies for the delay, we have discovered some internal issue that is likely to cause file format incompatibilities - we really don't want to risk this so we are spending some time resolving it.
In other news, progress has been made on the upcoming upgrade to the sketchup plugin. Below is a very early prototype (I believe it has already changed since).
What you are seeing is the Sketchup plugin directly using Octane standalone components. The troublesome flash code is slowly being removed
This has required some changes on the Octane core side, so it's a painstaking process to ensure that it has no negative impact elsewhere.
Removing the flash code and using Octane components means that we will be able to focus all the plugin efforts on ensuring that material and geometry synchronisation is more accurate and reliable. More details to come.
smicha
I've been dreaming about this for years :) Keep working guys. Good luck!
-rb-
Great Azen looking very much forward to it - again once this is all solved I'm sure the thing will take off!
- Rich
resmas
We are still here.
There is hope.
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
Jorgensen
i might have overlooked something but.....
i hope that the node editor somehow change or gets a search option - as it is now, when i open an existing model and want to edit a material - millions (well a lot) of nodes is displayed in a huge 'tree', and it is almost impossible to find the matrial.
jorgensen
haze
Jorgensen wrote:i might have overlooked something but.....
jorgensen
I can't check right now, but there is ctrl+f in the node graph for Octane. I'm not sure this is exposed in the plugin right now.
What we'd like to do is to allow picking directly in the viewport, and then selecting the material automatically.
The material node graph will soon be static, meaning that your changes in positioning of the nodes will also be persistent - this should help in organising the materials into groups, etc.
Perhaps at some point we can also look at some sort of layered node graph, or simply group material nodes together when they are grouped inside sketchup. It's too soon to tell though, but we're getting there.
smicha
haze wrote:....Perhaps at some point we can also look at some sort of layered node graph, or simply group material nodes together when they are grouped inside sketchup. It's too soon to tell though, but we're getting there.
Good - I hope my very old post on perfect exporter with proper nodal structure is still valid :)
Return to “SketchUp”
