Hello Paul,
... is this doable? just found the "assign random textures to instance script"... this would be really handy
best
Andreas
import lua scripts in octane4rhino?
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
You cannot use LUA scripts that Octane Standalone runs from the Octane Standalone Script menu, but you can use the Scripted Graph node which allows the running on LUA code. To do this, change the material node type to NodeGraph, then click Edit, rightclick the nodegraph and add an Other->Scripted Graph.
- fabrizio_s
I tried to do in this way but script didn't start...
If you can provide the script and the Rhino file that you tried, I can take a look. And also let me know which version of the OctaneRender for Rhino plugin you are using.I tried to do in this way but script didn't start...
- fabrizio_s
I use:
OctaneVR_3_05_1_win
OctaneRenderForRhino_3_4_3_74_SUBSCRIPTION
http://www.filedropper.com/bugwithtexturescript
Thanx
fabrizio
I use:
OctaneVR_3_05_1_win
Thanx
fabrizio
Hi Fabrizio
My understanding is that the LUA script that you are using is intended to run via the Octane Standalone Script system - rather than the Octane Scripted Graph node. For the Scripted Graph instructions, pls see viewtopic.php?f=73&t=42588.
