Is the same geometry with same number of layers, but the difference with big meshs in loading time is dramatic. You need to try the last maya plugin version and try to understand why.face_off wrote:The Octane engine used in OctaneRender for Maya is identical to that used in OctaneRender for Modo - so any difference you see would be at the Modo end (or your geometry in Modo has more vertices than in Maya).why maya plugin load meshs much faster? is it a new engine?
Tharso
