OctaneRender® for 3ds max® v3.04.3 - 4.26 [OBSOLETE]
Goldisart
paride4331 wrote:Hi acc24ex,
You are right, "use viewport backround" command works intermittently.
I will report the issue to the developers.
To use neutral background, you could save a gray rgb texture, to use as a reference,
just like in a photographic studios.
You should also have a calibrated monitor though.
viewtopic.php?f=27&t=58246
why complicate things .... implement Clipping warning is the solution to many problems
can do this and not to force to do stuff too ... the sun is shining - the monitor already shows a different sun changed the color and the white color is changed in the monitor.. for a perfect monitor should be the ideal dark room with the Windows closed and exposed to constant light.!!!!
------------- calibration and white of course necessary to monitor --------------
acc24ex
well the main point is to make "viewport backround" checkbox work as advertised
- works with a reload of a project, so probably just needs to force some local variable reload in the code..
paride4331
Hi acc24ex,
as mentioned earlier, it was already verified and reported to developers.
Using a grayscale panel was simply an advise.
Goldisart
when saving with an alpha channel to * Jpg - background black - you can choose for example white ?
paride4331
Hi Goldisart,
I will check if this is easily possible.
Elvissuperstar007
Live BD ( 3ds max ) simply freak, the one who made it so comfortable master
win 7 /64x C2Quad 6600 2.4/ Nvidia 9800 GX2 1gb 512 bit + Asus 480 GTX/ DDR2 8Gb / NVIDIA 460 GTX 2GB/2x NVIDIA 580 GTX 3GB
Goldisart
and it is better to enable the background .... what color or picture is then included in the alpha channel
AlexMakhov
Hi guys.
I have a big scene.
In a scene no one camera.
Render runs without problems.
Once you have created the camera in the scene and run OctaneViewport 3dmaks an error.
But if you create a camera running OctaneViewport error does not occur.
It still continues with later versions
paride4331
Hi AlexMakhov,
I tried to reproduce your issue with a scene of approximately 800mb. No error reported.
Could you kindly give further information or share a scene in which the issue occurs?
Goldisart
Brightness falls caustics is this normal ?
Return to “Releases”
