OctaneRender® for Maya® 3.05.2 - 9.18 [OBSOLETE]
Moderator: JimStar
JimStar
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2017 64-bit on Linux operating systems, and 2017 64-bit on OSX operating systems (including and above 10.9).
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
For network slave and daemon please download standalone installer here:
viewtopic.php?f=24&t=58323
CHANGES SINCE THE PREVIOUS VERSION
  • Few stability fixes...
Windows
DOWNLOAD
OctaneRender for Maya 9.18
OctaneRender for Maya DEMO 9.18
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 9.18 Linux
OctaneRender for Maya DEMO - 9.18 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 9.18 OSX
OctaneRender for Maya DEMO - 9.18 OSX
renmaxhb
2015 not rendering
calus
Haha, there's a lot more improvements than that in this version :D
For "movable proxy" geometry type, changing visibility now works with IPR,
and batch rendering animated visibility with " animation mode : movable proxy" also works.
This is a really really nice improvement, and solves lots of workflow problems with the plugin.
I really like the coherence of visibility treated as an additional transform property,
then it make sens that visibility is not updated for "scatter" geometry type, as the definition of scatter geometry is to not update its transform.
When this will also work for the ORBX exporter, there will be no more reason to prefer Maya builtin Alembic exporter I think.
Pascal ANDRE
Jolbertoquini
Hi Jim,
This version and the version and the older have some issues with maya 2017 for IPR doesn't starts at all maya crashs I have any error as a message. the 3.05.1 is working perfect.
aswell the sunsky default power was 1 and now in come back to 0.3???
Please could we have a fix for that?
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
calus
Jolbertoquini wrote: This version and the version and the older have some issues with maya 2017 for IPR doesn't starts at all maya crashs I have any error as a message. the 3.05.1 is working perfect.
Aff, too bad this version apparently doesn't work with Maya 2015 and 2017 .
For information, the plugin seems to work nicely in my tests with Maya 2016 sp6 windows .
Pascal ANDRE
HMXMedia
I am using maya 2017 and latest stable version Octane Render® for Maya® 3.05.2 - 9.18 [STABLE] is CRASHING MAYA as soon as we start IPR
Can you please give us fixed version
Jolbertoquini
Hi Guys,
I had also report a bug on Batch render at 3.05.1 page viewtopic.php?f=109&t=58254&start=10
Is about maya fluids is not working right on batch render.
Best,
JO
itsallgoode9
HMXMedia wrote:Hi,
Yep, I had the same problem. IPR start = Maya freeze. Maya 2017 also
calus
itsallgoode9 wrote: Yep, I had the same problem. IPR start = Maya freeze. Maya 2017 also
Finally I could reproduce IPR freezing also with Maya 2016,
I noticed the problem occur only if I have frame extension set to single frame.
But as soon as this is set for animation rendering, the problem disappear:
So maybe this is the same for Maya 2015 and 2017,
so if you want to use this release before it's fixed, just set render settings to animation instead of "single frame".
Pascal ANDRE
Renart
Thank you Calus!
It solves the freeze problem for me on Maya 2017 :)
Return to “Releases”
