I'm rendering a calendar with a bunch of pages each side of each page showing a different month. Each page has a mix shader set to "side" so I can put different months on each side of the page. In the live viewer, everything looks fine. If I render "current frame", everything looks fine. However, if I render the entire sequence, the textures are not on the correct pages and the alignment is off. Scene was initially built in 3.04.3. I updated to most current version in hopes it would fix this, but it's still there.
Apologies if this has been answered before. I only was able to find issues with lighting not matching and gamma issues on shaders.
Thanks in advance for any help.
Right textures in Live Viewer, but not in final render
How can we know that without seeing your scene? My estimation is you changed to "send all data" method for rendering or so. Do you have somethings to share?
- rseemueller
It's not set to "Send all data". As far as I can tell it's set on "Resend only updated objects" (unless there is another place that can be changed that I'd have accidentally adjusted). I can't share the scene as is, but I'll try to widdle it down and see if I can post it.
Sure! Very small example scene is enough. I don't want your whole content. Thx
- rseemueller
Not sure if you need the texture files or whether you can see the issue without them. If you need them, let me know. Thanks!
- CalendarOnly_Animation_161220_01.zip
- (636.59 KiB) Downloaded 118 times
- rseemueller
I figure you'll probably need them. I'm dumb.
I'm only sending a small portion of them though.
- CalendarOnly_WithTex.zip
- (12.62 MiB) Downloaded 125 times
- rseemueller
Hmm... 170-542. I made it to about 235 before I came back and noticed the errors. And yes, that disappearing page has also been an issue. Can't figure that one out either.
I'm still looking this scene. It's weird one. strange behaviour on C4D's itself also. Seems like a cache generation problem when it's opened. See video.
- 2016-12-29_00-22-21.mp4
- (4.69 MiB) Downloaded 2127 times
