Dust particles noise
wizkid
Hey folks
I'm doing some dust particles for a project. The particles are done i X-Particles. They have a glossy material on them, with film width to get the color variation.
Now, the render gets pretty noisy in the areas with DOF. I've tried increasing the samples to ridiculous amounts, but its still there, so guess I need to optimize somewhere else?
Hope you can help!
render settings
render settings
Particles with noise
aggiechase37
Try increasing path term power. Also, multiply your light source by ten, then lower the exposure of the camera by same factor.
Chase
Win 10 - Intel 4770 - 2x Nvidia 1070 - 32 gigs RAM - C4D r16
http://www.luxemediaproductions.com
coilbook
Otoy promised to fix/create less noisy dof with specialr materials including noisy bright lights reflecting in specuar material. I hope 3.1 will address this problem.
mesut
i tried and did a setup similar to yours.
would be interesting to know about your lighting setup.
my try with just one not so big area light led to extreme noise.
abother try with a huge area light that shines over the whole particle scene cleared eveything very quickly.
the fastest way, though, was to not use any are light, but to use an environment tag set to type "visible environment", while reflections being activated.
since you are using a glossy material for the particles that should do the trick. did it here, very fast.
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
wizkid
mesut wrote:i tried and did a setup similar to yours.
Hey Mesut! Thanks. I'll give it a go!
