problem with displacement in max and megascan
nildoe
Hi guys i need help figuring out what im doing wrong...I have this displacement from megascans that i cant use it properly in max and octane.. please pics, the megascans one is SO MUCH detailed than the max version...any idea what could be the issue?
I thought that maybe if i was to plug the exr that came from megascan it would fix, but it seems that octane's displacement feature does not support exr or 32bit tiff (tried to convert exr to tif 32bit with photoshop, upon trying to load the tif max says cannot read file, but photoshop can.
when using the jpg supplied from megascans i get the result you see here and is far from the same thing!! Im using cm as system units and a plane of 2mx2m big to test this.
Please help me Im getting desperate here! :(.
Im only getting this! very blobby with no details at all!
I want to get THIS DETAIL
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
coilbook
I think octane displacement texture also has quality setting
nildoe
Hi...yes it does and i set it at 4096 i also tried at 8192 even though i was using 4k maps..but i couldnt see any considerable improvement.
Thanks for replying btw. :).
Nildo
paride4331
Hi nildoe,
try to have a look at:
viewtopic.php?f=24&t=57108&p=294576&hil ... nt#p293332
nildoe
Hi Paride, thanks for the reply, i read thru it but still getting issues, sent you a PM.
Nildo
Return to “Autodesk 3Ds Max”
