How do i render passes on octane cloud?
thank you!
Render Passes?
something like this?aoktar wrote:ringleader wrote:How do i render passes on octane cloud?
thank you!
%r_%Diffuse_%4n.96e?
What if I require passes from info channel as well?
Is it possible to set all the necessary passes in c4d and use the ORBX export function from the C4D plugin?
As how it write in image. It will render out all selected passes except object masks. Take some test drive on ORC to be sure. And check this page: https://docs.otoy.com/#cinema-4d-v3-plu ... standalone
Thanks, Aoktar, will give it a go as I need ORC for a job in March. However, will we be able to download .ZIP file for all the images in the near future?aoktar wrote:As how it write in image. It will render out all selected passes except object masks. Take some test drive on ORC to be sure. And check this page: https://docs.otoy.com/#cinema-4d-v3-plu ... standalone
Best to directly ask to ORC guys. It's not a part of me.
