Octane Live Platform Testing Release (pre-23) [obsolete]
Hmm, I am getting some funny tearing when using two cards (attached). It is fine when using just one. It doesn't seem to be all scenes, as the Octane Benchmark is fine (69599 Triangle), but a 1,718,967 tri 346.8MB is not
I am also getting an error when I try and get Device information (attached).
If I set custom viewport control mappings to use RMB, it seems RMB only works with shift, no other combo with RMB seems to work. If I set Camera Zoom = RMB + Ctrl, this does not work, but middle mouse wheel still zooms.
Win 7 64bit | 2x GTX 285 | i7 920 | ASUS P6T Deluxe | 12GB
Whenever I try to save an image, Octane crashes, I tried several scenes, I imported meshes from scratch, I moved Octane folder to the root, made it run as Admin, nothing works.
http://www.OctanePowerTools.com
Octane Render Power Tools, Animation Tools for Octane Render
facebook | YouTube
Intel Core i7 920 @ 2.67GHz - RAM 12.0 GB
Asus P6T7 WS SuperComputer GTX 480
facebook | YouTube
no crash for you ?Diogo Moita wrote:Hi there,
Emitters are so very welcome, thank you! I´m sure that a lot of good interior renders will come up with this feature. The data basis ideia, will rock!!!
About bugs... the fire flies took over and I think you already know that (I´ll wait for MLT, no worries)![]()
That is a black line appearing on the botton. It appears colorful sometimes too. I thought it was related to multi gpus but no, it is happening on single gpu mode as well. And the emitter material stop emitting light. To fix this I tried to change the resolution and the kernel, and it worked. By the way, the emitter settings are the same on the first 2 shots. My machine is windows xp 64, i7 930, 12Gb and 2x GTX 470.
Win7 x64 - I7 920@4Ghz - 6Go DDR3 - GTX470
Also, when trying to move the picture i.e. Ctrl. + leftM it doesnt work. I can only scale the output down and up i.e. Ctrl. MiddleM.
facebook | YouTube
facebook | YouTube
- krzychuc4d
- Contact:
hi,
what is recommended driver version for this octane release ?
thanks
thanks
http://www.3structures.com
https://www.facebook.com/3structures
Ryzen 7 2700X / 32GB RAM / RTX 4070 @Win10 64Bit
- Elvissuperstar007
- Contact:
I thought it would be a line for each object .. turn on the light, but it is not (((very bad
on version 1.23 is not realistic to work
as you turn on the light?
Is that 17minutes rendering? (2.3 love it render)
Win 10. Threadripper 1920X 32gb Ram GTX 1080Ti GTX 980Ti 2xGTX 780
http://ajdesignstudio.co.nz/
