i have downloaded some free test models from here https://renderpeople.com/free-3d-model/ - and tried to use the material converter - nothing happens :-/
plugin version 3.03.3 - 4.25.
how to do it right?
jorgensen
how to use the material converter?
- paride4331
Hi paride4331
I have tried it, but my figure just stays white.....
I must try again (I'm not at my Computer right now), but I must be doing something wrong.
Jorgensen
Jorgensen
Hi paride4331
i made the mistake to merge the model into an other project. if i open the model then the converter works ok, but all materials are glossy, is that right?
- paride4331
Hi Jorgensen,
Yes is it right, vray material has a reflection, then octane transforms the material into a glossy.
The conversion is not always perfect, you should adjust the roughness that corresponds about glosiness (more or less) in vray (but in reverse).
