OctaneRender® for 3ds max® v3.04.3 - 4.25 [OBSOLETE]
paride4331
@acc24ex
hi acc24ex,
I attached a screenshot with the workflow to get a layer with shadows.
Kind Regards
Elvissuperstar007
batch render does not work, crashes after the first pictures
oguzbir
Setting the size value of displacement texture's 2d transformation to zero (by mistake) gives a crash.
Whilst Oct. Viewport is running.
A material having Displacement texture assigned to it (moveable proxy)
And Right clicking and Zero'ing out the 2d/3d transformation size value.. Gives crash.
In my example the displacement was set to a mix material.
My Portfolio
paride4331
@oguzbir
Hi oguzbir,
I checked the issues you had.
I will send this issue to the developers.
Thanks for your contribution.
paride4331
@Elvissuperstar007
Hi Elvissuperstar007,
making some testing, I found no issue.
Could you try my attached scene, does it crash to you?
01_2016B.zip
(199.31 KiB) Downloaded 258 times
acc24ex
paride4331 wrote:@acc24ex
hi acc24ex,
Kind Regards
wow, yes that's it, thank you, was looking for that .. activate the render layer, also the zdepth bug is gone - paride, you're a good asset to this team, definitely feeling the improvements
BTW
@elvis - tried your scene, works ok
richardyarlett
You still have not fixed the IMMEDIATE CRASH if you try to do anything with TEXTURE ENVIRONMENT in the Material Editor.
Just trying to access a TEXTURE ENVIRONMENT takes the entire session down instantly. So I cannot use this version.
Please comment on this.
Elvissuperstar007
Bug
bug.rar
(67.98 MiB) Downloaded 327 times
paride4331
@richardyarlett
Hi richardyarlett,
I'm sorry for the issue occurred, new developers are working to the best;
When a reported issue is not always reproducible, is not so easy to understand where fix it.
But that issue was not forgotten.
paride4331
@Elvissuperstar007
Did you use risers cable?
Return to “Releases”
