Dear Ahmet,
C4D R18 & Octane is not working well with HDR Light Studio.
It works find with R17, only R18 not responding to the changes.
Take a look at the video attached.
Y
R18 and HDR Light Studio
C. RAM Capacity (i.e. 6 GB)
- 2016-11-15_11-26-16.mp4
- (6.4 MiB) Downloaded 3175 times
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0
https://yambo.me
https://yambo.me
maybe it's related to the 5.x release of hdrl?
i've got it working as expected with r18 and hdrl release 4.x.
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
Did you asked to HDRLS guys before posting this as a bug?
You know, sometimes in the middle of a day of work i run into some bug / situation and just quickly jumping into to forum and post something here. This is the fastest solution for me without spending too much time on it.
I know it might be annoying, but my intention is not to post this as a bug from your side, because i really don't know if its your side, Otoy side, ot HDRLS side.
I will think twice next time to handle situation like this better,
Y
Y
https://yambo.me
https://yambo.me
Hi Yambo,
It works on C4D R18 and HDRL 5.3.5 , you need to setup the scene a little.
In C4D select the object/s and Export it as Collada (on the plugin window of HDRLS) so then you can view it on the viewport of HDRL (on render setting make sure that direction af Z is UP)
You can paint the light on HDRLS viewport and also directly on the objects on C4D viewport.
Hi Yambo,Yambo wrote:You know, sometimes in the middle of a day of work i run into some bug / situation and just quickly jumping into to forum and post something here. This is the fastest solution for me without spending too much time on it.
Y
I have discovered that the problem of wrong light direction of reflection and light is due to a change from Octane standalone 3.04.4 (see the change) the last one cause the problem. Fellow at HDRLS confirm me now and sent a request to Otoy to fix the problem.
The workaround is to change the setup of render as follow:
select Custom instead of C4D and then set 90° and check Flip
