Water in Houdini
Forums: Water in Houdini
Sub forum for off topic discussion
Water in Houdini
Postby RosKos » Sun Nov 13, 2016 11:26 am
RosKos Sun Nov 13, 2016 11:26 am
Hello, guys!
How make Octane see water in Houdini?
After rendering one can see only pink picture.
What you need to do to the water to be seen?
I recently started learning Houdini...
RosKos
Re: Water in Houdini
Postby juanjgon » Mon Nov 14, 2016 9:34 am
juanjgon Mon Nov 14, 2016 9:34 am
If you see only pink object, the problem is that you have not assigned an Octane material to it. You need to build a Octane material using the Octane vopnet or any of the Octane materials HDAs, and set this material in the object.
The small tutorial available in the docs could help to start:
https://docs.otoy.com/manuals/products/ ... ane-scene/
juanjgon
Postby RosKos » Mon Nov 14, 2016 4:51 pm
RosKos Mon Nov 14, 2016 4:51 pm
Thanks for the answer!)
With other objects everything is fine turns, but the water - no.
Everything is as it was pink, and remains ...
And there is an example, but with the water?
RosKos
Postby juanjgon » Mon Nov 14, 2016 5:08 pm
juanjgon Mon Nov 14, 2016 5:08 pm
Can you attach your scene to test it here?
juanjgon
Postby RosKos » Mon Nov 14, 2016 5:21 pm
RosKos Mon Nov 14, 2016 5:21 pm
Yes, sure!
Thanks!)
http://dropmefiles.com/lmNTr
RosKos
Postby juanjgon » Mon Nov 14, 2016 5:46 pm
juanjgon Mon Nov 14, 2016 5:46 pm
Well, the problem is that you are rendering both ocean objects, surface and interior. They are overlapped, and the interior one doesn't have a octane material assigned to it, so it is rendered pink.
If you disable the ocean_interior object, or you set a Octane material on it, all should work fine.
juanjgon
Postby RosKos » Mon Nov 14, 2016 6:07 pm
RosKos Mon Nov 14, 2016 6:07 pm
Yes, it works, thank you!
Only here there was another problem ... How to return the water its properties? (Waves, foam, etc.)
Now it's more like an ordinary box, filled with texture
RosKos
Postby juanjgon » Mon Nov 14, 2016 6:14 pm
juanjgon Mon Nov 14, 2016 6:14 pm
You need to build your own Octane material to simulate the water. I suppose that an animated displacement map should help with the ocean surface. I know that people exports the displacement maps from the Houdini ocean toolkit as image sequences to later use them in Octane.
juanjgon
Postby RosKos » Mon Nov 14, 2016 6:28 pm
RosKos Mon Nov 14, 2016 6:28 pm
Thank you!)
We'll have to work hard.
Thank you very much for your quick answers)))
RosKos
Return to Off Topic
Mon Jan 25, 2021 9:27 am [ UTC ]
