Material Transmission Bug?
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
nktrrz
It looks like when setting transmission to 1.0 in a diffuse material light does not "refract" properly and results in a dark material. Specular material transmission has this issue as well.
This seems to have happened in version 3.04.3 as 3.04.0 does not have this issue. I reset octane sops, shops, and render nodes between switching versions, but maybe I'm missing something.
Thanks Juanjo and the rest of the team.
Win7
4x 780ti3GB
32BG RAM
368.81
OctanePlugin_3.04.0.0 / 3.04.3.0
Houdini14.0.474
3.04.0
3.04.0
3.04.3
3.04.3
juanjgon
Sorry, I think that I can't reproduce this problem here. Can you attach a sample scene with this issue?
abstrax
nktrrz wrote:It looks like when setting transmission to 1.0 in a diffuse material light does not "refract" properly and results in a dark material. Specular material transmission has this issue as well.
Win7
4x 780ti3GB
32BG RAM
368.81
Houdini14.0.474
Yes, this problem was introduced with 3.04.1 and will be fixed with 3.04.4 which is being built right now.
nktrrz
abstrax wrote: Yes, this problem was introduced with 3.04.1 and will be fixed with 3.04.4 which is being built right now.
Ah, I see. Thanks.
juanjgon wrote: Sorry, I think that I can't reproduce this problem here. Can you attach a sample scene with this issue?
Sorry, I should have included a sample scene. But I think I can wait for 3.04.4. :)
Thanks for the quick reply guys.
juanjgon
Yes, this problem seems fixed in the new Octane build. I'll try to release a new plugin build ASAP.
WhyGee
Hi, I think this might be the same bug but just in case:
I'm having different results with hair transmission from previous builds.
Yaniv
octane_hair1_scene.rar
(154.02 KiB) Downloaded 350 times
juanjgon
Yes, can be the same problem. I'll post a new plugin build along this week with this problem fixed.
WhyGee
thanks!
Return to “Bug Reports”
