Octane beginner question
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
jochen.ulmer
Hello,
I am a new user from Octane. I try to make a material like this "silver color" on the picture. Can help me someone what settings I should use to make this?
Regards,
Jochen
Hi Jochen,
a first attempt of plastic to play with:
without bump
and with bump
You have to correct the scale base on your object and adjust here and there some values:
PlasticMat.orbx
(4.68 KiB) Downloaded 376 times
ciao beppe
jochen.ulmer
Wow it looks very cool. Thank you very much for the help. Is it possible that I open this material in Cinema 4D with Octane Plugin?
jochen.ulmer
Cool thank you!
jochen.ulmer
Is it possible to make the Material a little bit darker?
Hi jochen,
just add another color correction node between the clamp node and the diffuse pin and reduce its power as needed.
ciao beppe
jochen.ulmer
Thank you very much for your help.
Return to “Resources and Sharing”
