Thank for reporting! I'm checking now.KonstantinosD wrote:Hello Ahmet,
I think in this release the priority settings are messed up, If I choose for all my cards priority low, they go to full speed, If I don't choose anything (no tick) they go to low priority and if I tick they go to full speed no matter what I choose from the tab, (low medium high).
See pics Can you confirm the same?
Version 3.04.5-R2 (05.12.2016)-Previous stable
Some warning for people who use this version. There's a problem with empty distribution slot on arealights.
See: viewtopic.php?f=85&t=56929&start=40#p293198
Temporary solution until next build: viewtopic.php?f=85&t=56929&start=40#p293490
- mikeadamwood
Being a subscription user, I can't have access to these beta versions? I can download but cannot login...
Windows 11 Pro | ASUS Pro WSX80E | AMD Threadripper Pro 5975WX 32-Core | 256GB Micron 8x32GB 3200MHz ECC | 2x PNY RTX6000 ADA
You have to use VR versions. You can't login to standard versions with subscription license.mikeadamwood wrote:Being a subscription user, I can't have access to these beta versions? I can download but cannot login...
Not missing. I'm trying to finish builds. Some of them upped now.fpajonk wrote:Download links are missing for 3.04.3.
- Domenicozzo
- Contact:
Hi Ahmet,
Thank you for your constant work... I may have missed something but I went straight from the 3.03.4 to the 3.04.3 and suddenly all my objects with SSS materials are now darker than before, did something change about SSS between those 2 versions?
Domenico
Domenico
Don't know if somethings has been changed in sdk. Maybe something about normals or nonclosed volumes? Cheched you et material on a cube? What's kernel? Directlighting kernel needs manually tweak for gimodes.Domenicozzo wrote:Hi Ahmet,
Domenico
- Domenicozzo
- Contact:
thanks, Ahmet, it's in Pathtracing... the problem is that I've checked 5 different files with SSS materials in them and they've got all the same issue
You may need invert in absorption texture.Domenicozzo wrote:thanks, Ahmet, it's in Pathtracing... the problem is that I've checked 5 different files with SSS materials in them and they've got all the same issue
