Rendering Cube Map x, y, z Flips Scene in Octane Camera
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
solomonfl
paride4331 wrote:@solomonfl
Hi solomon,
I attached a screenshot about the cubemap baking workflow
Hi Paride4331, I tested this approach, because I am desperate for a solution ~ but when I replace the image as illustrated, all I get is a black render in Octane.
kindly show me a step by step on how best to use it ~ I think there are some steps missing. Do you have to add a light to the scene for example?
paride4331
Hi solomonfl,
I think you've just forgotten to select "Diffuse filter" instead of "beauty" pass.
solomonfl
paride4331 wrote:Hi solomonfl,
both the Beauty Pass and the Diffuse result in the same Black render ~ I have attached a screen grab.
paride4331
Hi solomonfl,
diffuse filter not diffuse
solomonfl
Thank you. So this is what I did. I went to my current scene and Selected Cubemap in the Octane Camera Type options.
Then Rendered out a Cubemap, which I used in the scene you provided.
Without Changing anything other than swapping out the Cubemap image in the material properties of the cube in the scene ~ I saved the resulting render cubemap and took it to
Unity, and added it as a Material, and changed the Texture type to a cubemap ~ in the preview all looks great ~ But when that cubemap is assigned to a Skybox and added to the Direct Lighting skybox option, the image is flipped back to that mirrored state I am trying to resolve.
paride4331
Hi solomonfl,
Do you have the same issue in the skybox with both cubemap then?
solomonfl
Hi Paride, I am not sure I understand what you mean by both cubemap?
paride4331
Hi salomonfl,
I mean, so have you problems with original cubemap and flipped cubemap too in skybox?
solomonfl
paride4331 wrote:Hi salomonfl,
Yes both of them for some reason.
That's why I am hoping that an option can be provided so there is both a mirror option and one that turns off the mirroring of the render.
Return to “Bug Reports”
