Max freezes with Octane sun and texture
C. RAM Capacity (i.e. 6 GB)
- mark0spasic
If I add octane sun and then add texture (RGB image) under octane sun/texture, if you pull texture to material editor my max freezes. This happens in every scene even empty. This happens in Compact material editor in Slate material editor everything is ok. This is using OctaneRender® for 3ds max® v3.03.4 - 4.19 [TEST] , Max 2014
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
- paride4331
Hi mark0spacic,
I tried to repeat your issue but not encountered this problem you reported.
Could you share a scene where you have this issue?
- mark0spasic
It happens in every scene even empty new scene I also tried with max 2016 same thing.paride4331 wrote:Hi mark0spacic,
- paride4331
Hi mark0spacic,
could you uninstall Octane 3ds Max and reinstall it ?
have you already tried?
- mark0spasic
I reinstalled Octane and problem persist.paride4331 wrote:Hi mark0spacic,
I never before had this problem.
In version OctaneRender® for 3ds max® v3.02 - 3.17 I don`t have this problem.
My driver version is 364.72 2xgtx780 win7
- paride4331
Hi mark0spasic,
Could you try to install OctaneRender v3.03.4 - 4.20?
- mark0spasic
I uninstalled OctaneRender v3.03.4 - 4.19 and I installed OctaneRender v3.03.4 - 4.20 and problem persist.paride4331 wrote:Hi mark0spasic,
Edit I left frozen 3dsmax 2014 and after about 5 minutes it become unfrozen. Same thing with max 2016.
- paride4331
Hi mark0spasic,
Could you try this sample scene? Do you find same issue?
- test.zip
- (157.46 KiB) Downloaded 254 times
- mark0spasic
I tried your scene, the moment I click on material editor my max freeze for about 5min.paride4331 wrote:Hi mark0spasic,
I even installed newest driver version 373.06
I concluded that if I add rgb image in environment tab (without octane sun) and drag it to compact material editor max freezes,
but if I add texture environment in environment tab and drag it to compact material editor works fine.
So it`s probably some problem with environment in combination with rgb image.
- paride4331
